10-25-2017
03:27
10:58
AndreaFitbit
10-25-2017
03:27
10:58
AndreaFitbit
Fitbit charge hr won’t set up , Any ideas ? Won’t let me go past the terms & privacy page!
Moderator edit: format.
Try a factory reset.
Are you getting to the 4 digit pin code
http://help.fitbit.com/articles/en_US/Help_article/1606
ALAN | VAN,B.C. Canada Community Council Member
Versa, Charge, Charge HR, Ionic, Ace, Aria 2 scale, Flyer headphones - iOS
Click here Fitbit help for more solutions
Hello @Rome92 it's a pleasure to welcome you to the forums, @ACG it's always nice to see you around! ![]()
This sounds really odd, as a friendly reminder, you must complete all the requirements in order to setup or sync without any trouble:
My suggestion is following these steps:
@ACG thank you for the awesome information shared in this thread.
Hope this helps, I'll be around!
What's for breakfast?Check others recipes and share yours!
I have tried setting up my Charge HR on my phone, tablet, and laptop without success. I have deleted and reinstalled apps, restarted my fitbit, and have moved away from my other fitbit devices. What are my options?
Best AnswerNot sure if this is helpful, but this was my experience with my latest Charge HR. I am using Fitbit Connect on Windows 7. I could not get it to setup. Support suggested uninstalling and reinstalling Fitbit Connect. That did not work. I must have tried eight times. Then I tried uninstalling the current Fitbit Connect and installing an older version. To my surprise, I got to the screen that showed the devices (never got past the point where it said it was updating my information on earlier attempts). Sadly, did not have the Fitbit handy!
Next time I tried (same version on Connect) it would not setup again. I tried reinstalling again, did not work. Reinstalled the newest Connect again, did not help. Decided to just randomly try running the Connect setup. About twelve attempts (over about a week) and for some reason setup worked!
I also tried scouring my machine and looking for Fitbit cookies and other folders left over from uninstalling the Connect app and deleted anything I found. But I am not sure if that mattered or not. Seemed more like I caught their server when it was in the mood to work.
Anyway, once I got it setup, I have had no problems syncing and I can use the new HR pretty much like the old one.
