01-15-2016
14:01
17:10
01-15-2016
14:01
17:10
01-17-2016 08:10
01-17-2016 08:10
Great to see you around @Vmoz. I agree with @WendyB, try the Restart Process since there's not an option to adjust the brightness of the display. If this doesn't work, feel free to go to the retailer and follow their exchange policy or contact our Support Team. For a faster solution you can contact them via phone or chat.
Let me know the outcome! ![]()
Best Answer01-15-2016 14:29
01-15-2016 14:29
Try a restart. Sometimes doing it a few times helps. You need to see the Version flash on the unit or it did not take.
Restart
http://help.fitbit.com/articles/en_US/Help_article/How-do-I-restart-my-tracker/
If that does not help then exchange it where ever you bought it
Wendy | CA | Moto G6 Android
01-17-2016 08:10
01-17-2016 08:10
Best Answer01-18-2016 01:20
01-18-2016 01:20
01-18-2016 03:14
01-18-2016 03:14
You are welcome @Vmoz. It it great to hear that you will be receiving a replacement tracker. You can follow our Setup Instructions to paired the new tracker to your current account without losing your information.
Keep the stepping up! ![]()
Best Answer11-22-2019 23:34
11-22-2019 23:34
so much bother.... this is a brand new replacement Charge 3 & it's playing up now 😕 I can't see the screen, it's very dark. I have repeatedly restarted the device. The reset line & little smile face are crystal clear. Unplug the device from the charger & the screen is as dull as before. Fitbit this time round has been nothing but trouble & frustration. Can anyone suggest another fix please
Best Answer07-03-2020 00:28
07-03-2020 00:28
I am having the same issue. The screen is perfectly clear indoors but I can barely see it outdoors. I have completed the reset, seen the line and smiley face but still no difference when I go for my run. Is this a design fault on the Charge 3?
