01-30-2019
15:45
17:54
01-30-2019
15:45
17:54
Hi, I'm new here, this is a long one so please bear with me!
My Charge2 was not working correctly, so I was sent a replacement from fitbit last week. I have deleted my old tracker from my app and my phone, however, the replacement simply will not pair to any of my devices! (windows 10 and andoid). I've tried turning Bluetooth on/off, restarting my devices, restarting the fitbit and uninstalling and re-installing the apps.
The fact that it wont connect to any apps / devices leads me to believe that there is a problem with the new tracker itself rather than any of my equipment.
Am I missing something?
Any help / advice gratefully received.
TIA.
01-30-2019 20:03
01-30-2019 20:03
Welcome to the forums @Penburr
Here is the article with instructions on replacing a Fitbit - click to go there
You might want to be sure to pick one device to set up with as having both on could confuse the Fitbit.
Which phone and Android system are you using? It might help to narrow down the problem.
Let us know what happens, so you can get tracking those steps!
Best Answer01-30-2019 20:03
01-30-2019 20:03
