05-08-2022
16:07
14:29
05-08-2022
16:07
14:29
Hi there, I went on holiday and my battery died. I tried multiple times to recharge using a USB port but the device did not charge. I decided to wait until I returned home 3 weeks later and I’ve tried charging on my laptop/usb port but the device is completely unresponsive. The charger and pins on the device are clean. I’ve tried pressing the side button but I get nothing. Can someone please help?
05-08-2022 16:52
05-08-2022 16:52
Hi, @Leeloo44 , sometimes when a Fitbit doesn’t seem to be charging, the real issue is that it has become unresponsive.
First, I would strongly recommend plugging your Charge 4 into a wall charger - not the USB port on your computer. It will be much quicker to respond if charged from a wall socket. Just make sure the plug is UL/CE certified. The wall plug you use for your telephone is ideal, assuming it accepts the Fitbit usb charging cord.
Once plugged in to a wall plug, give it a good two hours charge. Once it has had two hours, if the watch face is still blank, try the restart procedure: while it is still plugged in and charging (even if it doesn’t seem to be charging) press and hold the side button for at least 8 secs. If the Fitbit is in an unresponsive state you may need to hold for up to 20-30 seconds.
With luck this should revive your Charge 4.
Good luck, and let us know how it goes. Welcome to the forums!
Best Answer05-09-2022 08:18
05-09-2022 08:18
Me too with this issue. Mine happened over nite when I took it off for shower and didn't put it back on until this morning.
I noticed when I logged in that it hasn't synced since April 26th although it's been working find since then.
I'll try the wall outlet charge, but when I attach it to my computer and tried reset, it started vibrating and wouldn't stop till I disconnected it.
Also, I do see smiley face, however, nothing after that.
Any other ideas??
lynnann
Best Answer07-01-2023 01:56
07-01-2023 01:56
I have exactly the same. Did you find any solution?
karlien
