10-21-2019
18:44
12:06
10-21-2019
18:44
12:06
I had not charged my Fitbit as been away. Came home charged it up but the date was the same as when the battery run out. The message I keep getting is to turn on Bluetooth on my phone.but it is turned on. Any ideas? Thanks
10-22-2019 07:21
10-22-2019 07:21
Hello and welcome to the Fitbit Community @SallyMM
I understand your having a Bluetooth issue. I would suggest restarting your charge 2 to see if that will resolve your issue. Here’s how:
If restarting your Charge 2 a few times still doesn’t resolve your issue then I would suggest this:
log out of your Fitbit App
shut down your device completely
wait 1-2 mins then turn your device back on
now log into your Fitbit App as you normally would with your email address and password
try syncing now
😃 please let me know if this helps resolve your issue. Keep me posted
Best Answer10-22-2019 16:51
10-22-2019 16:51
Hi
i have tried both suggestions but the Fitbit still has the same issue date and time wrong, still giving message to connect to Bluetooth when it already is,
any other ideas? Thanks
Best Answer10-22-2019 17:13
10-22-2019 17:13
Hello again @SallyMM
Lets try this. I think it might be best to just reinstall your Fitbit App. That way the App gets promoted to access the Bluetooth again. You will not lose any data doing this.
Here’s how:
1. Log out of the Fitbit app and force shut the app by swiping up
2. uninstall the Fitbit App from your device
3. now completely shut down your device and wait about 1 min then restart your device
4. once your device has reloaded reinstall the Fitbit app by downloading it from the App Store
5. once it’s installed, log into your device as you normally would with username and password
6. don’t touch anything in the app...just wait until you get a prompt from your Bluetooth.
7. When prompted by your Bluetooth tap yes
8. now try to sync
😃 Please come back and let me know if this resolved your issue
