01-03-2020
12:46
15:39
01-03-2020
12:46
15:39
Appears to be stuck in 12 hour format. Currently showing 08.45 and it’s 8.45pm... a little annoying as this isn’t correct and can’t find how to change this to 24 hour clock? Or at least remove the 0 so it shows 8.45
can anyone advise please?
01-03-2020 13:04
01-03-2020 13:04
@MrsMcFluff You can put your clock to a 24 hour format, but you must do it on your fitbit.com (web) dashboard. You cannot change this from the app.
Log into your dashboard from a web browser. Then click on the gear icon in the upper right, then click on Settings. Scroll down to the Clock Display Time and change it to 24 hr. Click on Submit at the bottom.
There are also other clock faces available. From your app dashboard tap on your profile picture > Charge 3 > clock faces. If you prefer a 12 hr format, you might find one there that meets your needs.
Laurie | Maryland
01-03-2020 13:00
01-03-2020 13:00
Go to Fitbit.com and click on the gear icon at the upper right and then Settings. Scroll down to Clock Display Time and set it correctly. Then scroll on down and click on Submit and then sync your tracker.
01-03-2020 13:04
01-03-2020 13:04
Laurie | Maryland
01-03-2020 14:29
01-03-2020 14:29
Many thanks -done 😁
