07-29-2020
00:06
09:14
07-29-2020
00:06
09:14
How do i change the time on my fitbit? I charged it but for some reason the time on it changed
07-29-2020 00:08
07-29-2020 00:08
You can't manually set the time, but it should reset itself whenever it syncs to your phone or computer based on the time on that device. Does your fitbit seem to be syncing ok?
The other thing that affects the time is the time zone in your profile. You can check yours at https://www.fitbit.com/settings/profile If you do change it then you'll need to sync again to update your fitbit.
07-29-2020 07:23
07-29-2020 07:23
No I cannot get my Alta to sync
Best Answer07-29-2020 23:48
07-29-2020 23:48
ok. If we can get the syncing going again then hopefully the time will sort itself out.
The usual things I try when I get syncing issues are:
If none of those ideas work for you then it’s probably best to contact customer support via: contact.fitbit.com
07-30-2020 04:35
07-30-2020 04:35
