05-06-2019
13:39
16:26
05-06-2019
13:39
16:26
The Date on my Charge 2 is incorrect and the time did not change with daylight savings time. Help!!
Kathy
05-07-2019 08:16
05-07-2019 08:16
@J0urneys Welcome! It's good that the community is growing!
I will assist you with the time displayed on your Charge 2. You can change the time following these instructions. If you are using the automatic timezone setting then you could try setting the timezone manually. If the issue persist then change it to a different timezone, save and sync then change it back and either use the correct timezone or a location that shares the same one.
Let me know how it goes.
