02-12-2017
12:35
10:13
02-12-2017
12:35
10:13
How far does the phone need to be from the Fitbit in order to receive text or call notifications? I work in a facility where phones aren't allowed. So I can't have any texts or call coming through to the Fitbit.
02-12-2017 14:21
02-12-2017 14:21
@Adb5 Many things can determine how close your phone needs to be for the bluetooth to connect. Typically it is about 20-30 ft, but walls, type of materials, etc can all effect that.
Kelly | Oklahoma
Alta HR, Blaze, Flex 2, Charge 2, Charge, and Aria * IPhone 7+
02-12-2017 14:28
02-12-2017 14:28
So about 30ft and I shouldn't receive any notifications from my phone right?
02-12-2017 14:36
02-12-2017 14:36
possibly this would depend on whatever interferance is around, i often sync are receive notifications from 50 feetl
11-12-2017 12:31
11-12-2017 16:18
11-12-2017 16:18
I mean that Fitbit says the tracker needs to be within 30 feet to sync or receive notifications.. This is the old Bluetooth standards, BT 4.x is rated a lot further at 70 feet and bluetooth 5.0 is over 100 feet.
My phone is inside a metal structure and I'm across and down the street away and can still receive notifications.
To sum it up BT 4.x should easily go 30 feet in most circumstances and open air possibly 70 or more feet.
My phone says that a trusted BT device 80 fret away could possibly keep my phone unlocked.
03-27-2020 06:53
03-27-2020 06:53
I just purchased at Fitbit Versa 2 and I don't get calls or text if I'm 20ft away. I have a LG Stylo 5 connected.
03-27-2020 08:18 - edited 03-27-2020 08:21
If your closer notifications work fine?
This makes no sense.
the antenna orientation battery level and other radio devices may interfere. Baby monitors, WiFi, cordless telephones, personal 2 way radios, Bluetooth speakers all work in the same radio spectrum.
However I don't seem to see interference.
I get notifications while in the front of a mall store with the phone in the back. We also bring in our own WiFi, the store has its own, we may also have 8-10 wireless scanners each using Bluetooth.
03-18-2021 16:51
03-18-2021 16:51
Mine had went through one wall than about 100'.
