12-11-2016 17:44 - last edited on 09-09-2020 10:26 by MatthewFitbit
I just got my Fitbit last week and I am new to it but it seems to be tracking my running activities very well. I used it for the first while using an Elliptical and was very disappointed with the results. The Elliptical itself measures distance and calculates a calorie burn and although the Fitbit should calculate calorie burn better the distance is so far off. On the Elliptical I went 4.4 miles in 40 minutes but the Fitbit only measured 1.65 miles. Nowhere close. Could I be doing something wrong? There doesn't seem to be anyway to edit it either.
01-01-2018 06:09
01-01-2018 06:09
01-01-2018 09:11
01-01-2018 09:11
I was wondering why can't the fitbit dashboard accept input about the elliptical distance? Referring to the place that you can enter activity. It would work like override. This should be something that the fitbit company should work on developing. Just a practical/serious thought. Seems to be an easy fix; especially since a lot of people, especially those of us who use the elliptical. Winter time in the northeast makes ellipticals an especially great choice option!
01-01-2018 11:48
01-01-2018 11:48
@SunsetRunner your tracker can auto detect elliptical without the user doing anything. Some people prefer manually starting the recording.
So why does it have it. First so the user knows they where doing this exercise. Second so Fitbit knows how to handle the data and give proper credit for calories. .
01-01-2018 16:03
01-01-2018 16:03
01-02-2018 05:09
01-02-2018 05:09
Do to limitations of e location of the tracker on relation to the pinning wheel, it will be impossible for Fitbit to determine your Norditrracks made up distance, based on the size of the wheel and the gear ratio I between pedals and wheel. I say made up because the person and the machine never moved an inch. Only a wheel spun near the feet.
When you say it is not accurate. What is the heart rate, calories probably will not match perfectly since every company has their own secret math formula.
01-02-2018 06:41
01-02-2018 06:41
Hi! I really do appreciate all of the other benefits. At this point in my "older" years...distance is my motivator. Thank you for responding.
01-02-2018 06:44
01-02-2018 06:44
Hi! Thank you for responding. Maybe if everyone complains to Fitbit corporation they will positively respond to this issue?
01-28-2018 14:20
01-28-2018 14:20
Why isn't there simply an option to update the distance with the info from the elliptical.
That at least would mitigate the issue.
01-28-2018 20:58
01-28-2018 20:58
Same problem with treadmill
shows 1.50 miles every time I walk 30 minutes
never the correct distance on my fitbit
what is going on?
01-28-2018 21:48
01-28-2018 21:48
@enyfeo simply because this is not available with any exercise. Why not vote for the suggestion.
https://community.fitbit.com/t5/Feature-Suggestions/Have-the-Ability-To-Edit-Exercises/idi-p/574994
01-29-2018 05:13
01-29-2018 05:13
01-29-2018 07:44
01-29-2018 07:44
01-29-2018 08:50
01-29-2018 08:50
wrote:
It appears that 850+ people have voted for this suggestion over three years
and nothing has happened.
Carla
It was more like a few people voting for many desperate but same suggestions, then last month they where merged.
01-29-2018 08:57
01-29-2018 08:57
01-29-2018 13:12
01-29-2018 13:12
12-06-2018 08:24
12-06-2018 08:24
The point is, that it is NOT accurately determining the miles, steps, calories, and often in my case, it doesn't even always recognize the activity, even when my arms are on the handles. It should allow for entry of the accurate data as a work around. Hard to keep accurate stats of activity otherwise!
12-06-2018 10:42
12-06-2018 10:42
Many are upset that Fitbit even records steps for this non stepping activity.
As for distance it is kind of hard to measure when the wearer is standing still. That is why Fitbit uses time and heart rate to determine calories.
Steps as distance isn't used
12-06-2018 10:54
12-06-2018 10:54
12-06-2018 11:01
12-06-2018 11:01
12-19-2018 03:31
12-19-2018 03:31
i don’t understand why there is no option to add/edit distance for elliptical workout like there is for all the others? wouldn’t this simply fix the problem we are all having? i edit all of my run/treadmill distances to be accurate to what i actually ran in case it is ever off by just a little, so why not on elliptical
