09-01-2017
07:11
09:26
09-01-2017
07:11
09:26
Apparently I was sleep walking (37,015 steps), or there is an issue with step counts resetting. Is there a way to reset the count back to 0?
09-01-2017 08:00 - edited 09-01-2017 08:01
It's nice to see a new member around the forums @MeghanG! Hmmm... this is very strange let me say. Is this the first time you experience something like this? Do you remember if yesterday you finished the day around 37K steps or so? If this is the case, it seems that your tracker forgot to reset its information at midnight. When this happens, even if you try to restart your tracker, delete the app, negate the steps, this won't work. Everything will be back to normal the next midnight when your tracker resets the information as it should. ![]()
On the other hand, if you were driving and your tracker added those steps, it is not possible to delete steps and floors, but you can achieve the same result by negating them:
Hope this helps, keep me posted!
Best Answer01-10-2019 12:53
01-10-2019 12:53
So following these steps fixes the dashboard but it doesn't back the steps out of challenges or badges. How do I fix that?
