07-17-2019
04:20
19:58
07-17-2019
04:20
19:58
I had to restore my iphone 7 and the Fitbit app didn’t grab all the information once the phone started. I ended up adding the charge HR and have lost everything from this year. Is there a way to get it back?
07-17-2019 06:17
07-17-2019 06:17
Make sure you are using the same account/email. If so, the only data lost should be since the time you successfully completed a sync.
Take a look at the data on the fitbit.com dashboard. That usually accurately reflects the data from the fitbit database, while the display on the phone can be flaky.
07-20-2019 15:52 - edited 07-20-2019 15:55
Duplicate
Best Answer07-20-2019 15:54
07-20-2019 15:54
Let's check your history on your profile. Then let's go to your settings. At the top you will see your registered email.
Now log out of your Fitbit app and log into your Fitbit account using this email.
