10-06-2019
23:47
12:16
10-06-2019
23:47
12:16
So how do you keep the button pressed while releasing the charging cable? Every time I try to release without letting go it doesn’t work and I am scrolling through the device.
10-06-2019 23:59
10-06-2019 23:59
Can I check what fitbit you have - the help file you quote is for a factory reset of the Charge and Charge HR. The Charge 2 doesn't have a factory reset option.
Are you sure you need to factory reset - it's a pretty drastic step. What problem are you having?
