01-03-2020
03:17
15:40
01-03-2020
03:17
15:40
I have tried resetting my charge 3 but the display is so hard to see. I have changed the clock face and still nothing. Can hardly read the screen anymore. Pleaas advise.
01-03-2020 07:19
01-03-2020 07:19
Try the Brightness Setting at Max.
Best Answer01-03-2020 17:30
01-03-2020 17:30
It only has auto, normal and low and they are are almost impossible to see most times.
Best Answer01-03-2020 18:19
01-03-2020 18:19
I had same problem. It cannot be fixed. Contact support. They will make you try a few things and perhaps you will have to contact them more than once but eventually they will send you a replacement.
