11-06-2020
00:37
13:00
11-06-2020
00:37
13:00
My fit it hasn't updated since 18th October. I have restarted it to no avail and deleted the app and reinstalled again to no avail. Coincidentally my partners fitbit has exactly the same issue from the 23rd October. I have only just noticed as it still records daily but doesn't update. So all the history has been zero since 18th October.Please help.
11-06-2020 03:51
11-06-2020 03:51
Hi,
I have the exactly same problem with mine. Mine stopped on the 17th October and like you I didn't notice until a few days ago.
I have since been trying to resolve it, deleted the app installed it but I can't even get mine to re-pair with my phone now !!!
Very frustrating and annoying, any info from anyone out there would be greatly appreciated.
11-06-2020 04:18
11-06-2020 04:18
I am having the exact same issue, and no idea what I should do! 😞
11-06-2020 04:46
11-06-2020 04:46
I have tried to re pair too and it won't connect so now in a worst position!! Run out of ideas...
11-06-2020 05:04
11-06-2020 05:04
I am having the same issue, and I have tried everything. I even called customer support and she tried to help me. After several minutes on the phone she asked me what kind of phone I had and when I told her she said my phone was not fully supported so it may not work. I explained to her that this is the only phone I have used for my fitbit and I have had fitbits for over a year with no problem. I told her I did not have this problem until their last update, and she said they are always looking at way to improve service. Well, I think they failed with the last update...It is very frustrating!!!
11-06-2020 06:01
11-06-2020 06:01
I have just spoken to my mum as I got her one when I purchased mine, she is having the same problem, so I was then thinking is it the phones?
We both have Hauwei, different models but I know there is issues Hauwei !!
Best Answer11-08-2020 12:03
11-08-2020 12:03
Yes looks like it is.. Next stop HUAWEI.. I will let you know if I get anywhere.. Big if though.🤔
11-08-2020 12:56
11-08-2020 12:56
Yes probably will be a big if but yes keep us updated,.
