07-28-2022
12:24
14:04
07-28-2022
12:24
14:04
My face is dim - cannot read the fact of my Charge 4 - what do I do.
07-28-2022 12:32
07-28-2022 12:32
There's a brightness setting. You may have accidentally set it to dim.
With the display on swipe left twice and look for 'Settings'. Tap it and Brightness will be the first one displayed at the top. Tap it to cycle through the three options: Auto, Normal, and Dim
Hope that helps.
Best Answer07-28-2022 12:32
07-28-2022 12:32
Hope that helps.
Best Answer07-28-2022 12:45
07-28-2022 12:45
Thank you so much - it worked. I looked and could not find an answer.
Best Answer08-16-2022 05:52
08-16-2022 05:52
How can you go to display in settings when it’s so **ahem** you can’t see it?
