08-25-2022
07:46
15:41
LucioFitbit
08-25-2022
07:46
15:41
LucioFitbit
So glad that the coders at Fitbit got the unacknowledged syncing problem figured out. Now, if they can just get the website to quit logging me out even when I've clicked the Keep me logged in box, I'll be semi-happy.
01-02-2023 15:50
01-02-2023 15:50
Hi there @wudzep, it's good to see you around in the Community.
I appreciate the comments and feedback. I'd recommend you check you have the latest Fitbit Firmware and OS of your mobile device.
Or try to logout of your Fitbit account in all devices and then open it only in the ones you are using your Fitbit account.
Also check these articles, How do I change or reset my Fitbit password?, How do I protect my Fitbit account with two factor authentication? and How do I use the Fitbit app?.
