07-29-2019
04:28
14:11
07-29-2019
04:28
14:11
Hi
I have been using Fitbit Charge 2 since 24 months now and since 3 weeks I observe that my Charge 2 is not able to withstand even for 10 mins after fully charged and it started all of a sudden. Please can someone help me to resolve this issue or if someone faced a similar situation and able to resolve it. Spoke to Customer care and they said its hardware issue and nothing can be done to rectify it.
If some one has a solution for this sort of problem, please let me know.
07-30-2019
09:38
08:10
07-30-2019
09:38
08:10
@KarthikReddy, welcome! Thanks for being part of our Community!
Let me help you with your Charge 2 battery draining quickly and thank you for reaching out to our Support team. Try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves. You can also find additional suggestions here.
Let me know how it goes.
Best Answer08-06-2019 06:10
08-06-2019 06:10
My Charge 2 also started draining within 10 minutes the day after the last firmware update.
Best Answer08-06-2019 23:01
08-06-2019 23:01
