08-20-2019
18:13
21:37
EstuardoFitbit
08-20-2019
18:13
21:37
EstuardoFitbit
The watch was working great. Had it for 2 years. Tonight it was running low on battery power so I plugged it into the charger and doesn’t show any charge happening ? Unplugged and tried numerous times. It’s been an hour and not charging ??? Any ideas
08-21-2019
07:25
11:19
08-21-2019
07:25
11:19
@Jayleafrap77 A warm welcome to our Community!
Let me help you with your Charge 2 not charging. Try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves.You can also find additional suggestions here.
I also moved your post to the correct board.
Let me know how it goes.
Best AnswerI have the same problem and tried everything to fix the problem. I'm suspicious that Fitbit has done something to cause this, forcing people to buy a new watch.
