08-16-2020
01:09
09:08
08-16-2020
01:09
09:08
Hi I need to get a replacement strap for my fitbit charge 2 - but it seems fitbot no longer stock the charge 2
Will a replacement fitbit charge 3 strap fit?
If not where can i get a fitbit 2 replacement strap from?
Thanks David
08-16-2020 07:19
08-16-2020 07:19
Charge 3 straps do not fit.
You can find a wide variety of third party Charge 2 straps on Amazon at very reasonable prices.
Best Answer08-16-2020 07:19
08-16-2020 07:19
Best Answer08-16-2020 07:24
08-16-2020 07:24
thanks very much for that tip - i will order via amazon then
Best Answer10-24-2020 06:35
10-24-2020 06:35
I’ve ordered a few fit it charge 2 straps from amazon but they don’t seem to fit them (there are extra metal connections on the ones I’ve ordered even though they say they are for charge 2. Was the design changed do you know in the models?
Best Answer08-15-2021 16:50
08-15-2021 16:50
They lack in quality and won't be able to use them fot more than an hour
