Fitbit Charge 3 Not Working
ANSWERED
I haven’t used my watch since the start of the year. However, I charged it recently thinking I could use it again and the screen was pitch black although the green light and vibrations were working! I tried to reset and change the watch face but it still remains black… what do I do?
Moderator edit: format and label.
1 BEST ANSWER
Accepted Solutions
My Charge 3 also was unresponsive. What finally worked was to delete the device in my account and reinstall it by selecting add new device. I also shut down and restarted my phone prior to that whole process.
6 REPLIES 6
Try a "Factory Reset" by performing these steps:
  • Attach the charging cable.
  • Press and hold the button for approximately three seconds ,and without letting go of the button:, remove the charging cable.
  • .Wait about ten more seconds after removing the charging cable.
  • Let go of the button and hold it down again
  • After "ALT" and a white screen flash, let go of the button and hold it down again.
  • .When you feel a vibration, let go of the button and hold it down again.
  • When you see "ERROR," let go of the button and hold it down again.
Hopefully your Charge III is good to go again.
Fitbit user since September 2019
Sense2 Sense, Charge3, Android, Windows
which button do I hold down?
The button is related to that groove on the left side of the tracker when you have it on your wrist. The easiest way to get it to respond is to connect to the charger. When connected to power it should leave the left side button exposed.
Welcome to the Fitbit Community, @Anonymous725190. I'm sorry to hear that your Charge 3 is not turning on and thank you for letting us know that you tried to reset and change the clock watch.
I noticed that you got in touch with our team and received assistance.
Thank you for your help @LokeAa
See you around.
Welcome to the Fitbit Community, @SunsetRunner.
Thanks for sharing the steps that worked for you in order to make your Charge 3 respond. I'm glad that you're back on track.
Keep on visiting the forums.
