01-08-2020
04:21
19:53
01-08-2020
04:21
19:53
Hello,
The last time I used my Charge 3 was in August, so the battery had died and needed recharging when I tried using it again earlier this week. It used to work flawlessly but is now having constant syncing issues.
It takes a long time to pair, will sync once (if I'm lucky) and then it will lose track of time and not sync again - so I'm glad I set a phone alarm as backup for work this morning! I've followed the syncing guide step-by-step (multiple times) and if it does sync then it'll only be for a very short period.
Details:
Device: Fitbit Charge 3
Phone: Samsung Galaxy S10e
Android Version: 10
I'd greatly appreciate further support but am doubtful it'll take anything less than a new device to resolve.
01-08-2020 06:56
01-08-2020 06:56
Update - it's now even worse:
Is there any way I can revert to an older version of the Fitbit Android app so that I can see if it's app related?
Best Answer01-09-2020 06:50
01-09-2020 06:50
Update 2 - Hardware, Hard Times Edition:
Questions:
As far as I'm concerned there's nothing else for me to troubleshoot - unless someone more knowledgeable (i.e. forum moderator) can provide any sort of assistance. All I can assume is that the tracker is indeed faulty.
Best Answer01-09-2020 12:40
01-09-2020 12:40
Try connecting Charge 3 with power adapter to charge it, then close phone bluetooth, wait 10 secs, then open bluetooth & see it it connects withing 20 minutes
Not satisfactory, I know, but this usually works for me
Don't know why
Best Answer01-10-2020 04:29
01-10-2020 04:29
Hey Tony, thanks for getting in touch with that tip.
I managed to get in touch with Fitbit via live chat support yesterday. It took 78 minutes before I was told that it's an ongoing issue with Android 9+, and that they hope to resolve it in the next app update. I asked for a rough time for when to expect this update, but they could not provide that.
If what support informed me is accurate then I would think it best for Fitbit to be transparent about this issue and inform their customers so that they, unlike me, don't have to spend hours troubleshooting - only to find there's no permanent fix outwith an update to the Android app.
Best Answer01-10-2020 05:45
01-10-2020 05:45
Hi Daag
My Android is 8 Oreo so should be the 9 problem. but there is a problem
Last night it lost nearly an hour so through I got up an hour early, therefore my sleep so too short or so Fitbit thought!
The amazing thing is that it worked perfectly for 9 months
Best Answer01-10-2020 06:22
01-10-2020 06:22
Just tried it on another Bluetooth device ( wife's table with Android 6). Exactly the same problem so I think it could be a worn out Fitbit. Hw do I get it replaced?
Best Answer01-10-2020 07:39
01-10-2020 07:39
Must be an 'on-going' issue with iOS 13.3 as well. Having same problems with my iPhone 11 Pro.
