05-09-2019
		00:23
		11:08
		05-09-2019
		00:23
		11:08
I have had my Charge 3 since October 2018 and its been working fine.. I’ve been very happy with it.
Suddenly last night it just died. I put it on charge thinking the battery must have ran out (though was unusual as I knew it wasn’t due for a charge).
When I plugged it in to charge the smiley face came up and said it was charging (1%)... I have left it overnight and when I removed it from the charger.. it seemed ok and had a 100% battery but then soon died and now back showing charging at 1% or just a white line when I attach it to the charger.
Anyone else had this problem? Can I get a replacement?
05-09-2019 00:51
                              05-09-2019 00:51
Hi @Meizilla Try restartingnit several times. If that doesnt fix it, try a long restart, but if that doesnt work either then please come back here for further help
CHARGE 3 LONG RESTART
Plug the device into the charging cable. While the device is plugged into the charging cable, hold the button down for 15 seconds. Remove your finger from button. Note: Device won't have a smiley face icon and should be off with a black screen. Remove the device from the charging cable. Plug the device into the charging cable again. The smiley face icon appears on the screen.
Helen | Western Australia
05-09-2019 01:17 - edited 05-09-2019 01:19
Thanks Nelly
That seemed to have sorted the battery issue - I synced after long reset while in the charger.
I’m keeping an eye on it but it seems to be behaving strangely. The side button is intermittently unresponsive and the screen gets stuck and vibrates on the screen wake/ notification options screen randomly on its own.
Any other ideas? I can try doing resetting and resyncing?
 Best Answer05-09-2019 01:36
                              05-09-2019 01:36
If you are still having problems after doing several restarts and long restarts then come back here again.
05-09-2019 05:32
05-09-2019 05:32
Tried a few resets.. seemed to be ok.. I’ve gone out about my daily business and it’s now just randomly vibrating and flicking between all the displays randomly and the side button is unresponsive.... it’s quite uncomfortable
Is there anything else I can try?
 Best Answer05-09-2019 05:53
                              05-09-2019 05:53
If you've dont long restarts, no, nothing else you can do. I will flag a moderator to come and help you.
 Best Answer05-09-2019 06:28
                                          Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
                              05-09-2019 06:28
Welcome to the Forums @Meizilla. Hello @NellyG.
Thanks for bringing this up @NellyG. @Meizilla Thanks for trying all of those steps and listing the details on what is going on with your Fitbit.
I have reached out to our support team so that they can get in touch with you @Meizilla. They will be sending you an email so please keep an eye on your email's inbox, spam and trash folders. They will be more than happy to help you figure out what is going on.
Let me know if you have any further questions.
 Best Answer03-31-2020 17:11
03-31-2020 17:11
My fitbit charge 3 is doing exactly the same as Meizilla is saying hers is doing. I have charged it on 3 different sites, cleaned points, long charges and re-booted as told. A white line appears and it keeps strongly vibrating with notifications awake. Smiley face shows 100% charged but then dies with no battery showing. What can be done pls?
 Best Answer03-31-2020 17:48
                              03-31-2020 17:48
Hi @Briggsy12 You will need to contact Support.
 Best Answer05-13-2020 08:46
05-13-2020 08:46
I am having the same issues as well - I have tried the long reboot, still not working. Turned back in and it is constantly vibrating and flickering and now showing the wrong date and time. It quickly dies as soon as I take off the charger.
 Best Answer05-13-2020 18:36
05-13-2020 18:36
 Best Answer08-08-2020 23:54 - edited 08-08-2020 23:55
Update to my original thread 14 months later - the replacement pebble Fitbit sent me last year has just died... ! Tried the usual resets.. it was going nuts yesterday - I put it on charge and this morning blank screen before heating up and going completely dead...Seems the tech doesn't seem to ever make it to 18 months.. this has happened to all my Fitbits! Might be time to switch to something else if wont replace it again. 😞
Raising a request with Fitbit support now!
