11-10-2018
15:39
15:03
11-10-2018
15:39
15:03
I got fitbit charge 3 .. 3 days ago and the sleep hasnt been tracked in the fitbit. I see everything tracked in the phone app but it wouldnt sync. Ive restarted the tracker several times but nothing has changed so far. Whats a possible solution?
11-11-2018 05:28
11-11-2018 05:28
Welcome to the Forums @Nitin3.
Let me help you get the sleep to show up in the app. I will be moving this to the Charge 3 board as I think it is better suited for it.
The first thing I'd like to recommend is that you try reading through this help article. It explains how sleep is tracked and so should provide some details as to what is going on. My particular suggestion is to check the sleep setting that you are currently on, you can find that information at the very end of the article. If you are on normal, try moving it to sensitive, or the other way around, to see if that helps with the sleep tracking.
Let me know if there are any further questions.
Best Answer11-11-2018 14:09
11-11-2018 14:09
Best Answer11-11-2018 18:02
11-11-2018 18:02
Are there any other devices that you can activate? My sleep is sync'd with a tablet in my bedroom while my phone handles everything in the day. The other night my sleep didn't track but when I got it in range of my phone instead of the usual tablet it caught up. There was also a software update that when I applied it on the tablet and rebooted it things started working again.
Usually when sleep doesn't sync the problem is with sync in general. You need to check the dashboard and notifications to make sure they are OK. In otherwords is sleep being ignored or is it collecting data but not sending it to your device.
Best Answer11-12-2018 09:50
11-12-2018 09:50
@Nitin3 Thanks for getting back to me, for going through those steps and restarting your Fitbit.
My question in this case would be, is it not showing anything at all on the Fitbit? Or does it work? Additionally, do you get some sleep data or nothing at all on the app? It seems like you are experiencing two separate issues.
There is no reason why everything syncs but not sleep data. The possibility in that case is that sleep is not being tracked at all.
Look forward to your reply.
Best Answer11-12-2018 14:02
11-12-2018 14:02
Best Answer11-12-2018 16:18
11-12-2018 16:18
@Nitin3 wrote:
Well my tracker shows - Sleep not tracked. However, on the phone app it is tracking everything. It shows the number of hours I slept. When I woke up etc. etc.
This is a known bug. As long as it is showing up on your device just try to ignore it for a bit ![]()
11-13-2018 08:19
11-13-2018 08:19
Thanks for coming in to help @CLTGreg, greatly appreciated.
As @CLTGreg said, it is a known situation. As soon as we have anything to share on the matter we will be sure to let everyone know about it.
If you have the time, in the meantime, maybe you could visit one of our Discussion boards. Lots of different topics to talk about with other users.
Let me know if you have any further questions.
Best Answer01-21-2019 09:08
01-21-2019 09:08
Has this been fixed yet, as I have the SAME problem.
01-22-2019 09:15
01-22-2019 09:15
Hello @detadawn.
Thanks for jumping in and letting us know that you are also experiencing this situation.
At this moment we do not have any details on the matter but please know that we'll be sure let everyone know as soon as we have any details on the matter.
Feel free to reach out with any further questions.
Best Answer01-23-2019 06:44
01-23-2019 06:44
My sleep has not been synchronizing since 30 December 2018. Could it be related to the heart monitor? My resting heart rate is not synchronized since then in the fitbit app, but my heart rate does show on the watch.
Best Answer01-25-2019 11:29
01-25-2019 11:29
Hello @Snaken.
There are some possibilities as to why this is going on:
Let me know if none of the above could be the cause or if there are any further questions.
Best Answer01-07-2020 23:43
01-07-2020 23:43
this bug still lurking this year 2020. do you still have dev for this? why still unfixed?
Best Answer01-08-2020 00:52
01-08-2020 00:52
hallo! Ik krijg geen uitgebreide analyse meer..wat betreft slaap..wel hoelang ik geslapen heb maar niet hoelang in rem, diepe, lichte slaap en score en vergelijking. Hoe kan ik dit veranderen?
Groet Janneke hermsen
Best Answer02-24-2020 00:30
02-24-2020 00:30
Same issue here. Got my fitbit 2 days ago. It tracks sleep on the app but it is not syncing the sleep data to the fitbit. It still says sleep not tracked even though I've tried syncing and restarting multiple times.
Please solve this
Best Answer02-25-2020 18:33
02-25-2020 18:33
what I did was I just return to the store where I bought the product. Then I ask them why you are still selling faulty products? there's really a problem with syncing data from the android device to the Fitbit charge 3. Then I just comment on all the reviews of this product on youtube that this is a FAULTY PRODUCT which has been a problem since 2018 and until now they didn't even fix it. I have an email from the Fitbit support that recognizes there lapses of the problem. I can share it if someone wanted some proof.
