03-25-2021
23:09
04:30
WilsonFitbit
03-25-2021
23:09
04:30
WilsonFitbit
My fitbit 3 has worked fine for several months. When I got a notification, it buzzed, and i could flip my wrist and read it no problem. Just the other day, it randomly stopped buzzing completely. Even if I do a short hold on the side button that brings up the Settings menu, it doesn't do the quick vibration like it used to. When I plug it into the charger or remove it, it doesn't vibrate like it used to. When I receive a call, it doesn't vibrate the screen stays black unless I tap the screen. 10 minutes before the hour it doesn't buzz for the 250 step reminder
It's acting like it's in sleep or DND mode. From the menu on the fitbit, i've turned off and on dnd, sleep, and screen wake multiple times trying to get it to start working again. The screen may also be a bit dimmer than usual but I can't tell for sure
Here is what else I've tried which hasn't helped:
I plugged it into the charger and did the 8 second restart(multiple times)
I cleared user data from the device and re-paired it
Updated fitbit app to the latest
Validated there was not a firmware update available for my fitbit(it's on 1.88.11 which is the latest)
From the fitbit app, disabled notifications, turned on Always Vibrate, disabled and re-enabled notifications
Unpaired my device and re-added it(several times)
I rely on my vibration notifications because I have to keep my phone muted and commonly use two hands and can't pick up the phone
Moderator edit: format
03-26-2021 04:34
03-26-2021 04:34
Hello @rcm2 Welcome to the community forums!
Thank you very much for the information and for the troubleshooting steps you've followed prior to posting! At this time, I believe the best way to get help is to contact our Support Team. You can contact them through chat or over the phone. Make sure to explain the inconveniences and the troubleshooting steps you've followed, this way they can assist you from there. Click here to get connected.
See you around.
