09-02-2019
19:53
17:01
09-02-2019
19:53
17:01
I have checked out the other answers on the forums, but they don't really address my difficulty. I wore a Zip for years, and loved it. It did exactly what I wanted it to - it counted my steps. They are no longer sold by fitbit. A few years ago I thought I would upgrade to a Charge, and used it for a little while and didn't like it, so went back to the Zip. Now I have had to resurrect the Charge and find it is even worse than I remembered. My difficulty is that I am in my 60s and my balance is poor, so I have to hold the rails when using a treadmill, and when walking I have my hands in my pockets. Even with the Charge set to non dominant, it is only registering very infrequent steps - but might register some of movements when I clean the cupboard doors! After spending 30 minutes on the treadmill and registering about 200 of these steps, I am ready to scream 😞 If I cannot work a solution on this, does anyone have a recommendation for something that works like the ZIP? Thanks.
Wrist models need to see the arms swinging
You could try An Inspire with the Clip it should register what you do
Wendy | CA | Moto G6 Android
Thank you Wendy. I will check that one out. I had a feeling it wasn't going to be an easy fix. I had thought of trying to attach it around my bra, but not sure that would be the most comfortable 😉 Does the Inspire come apart, or does the whole thing fit into the clip? I had never seen that before - I am wondering whether it would be possible to use the Charge in the same way?
Best AnswerThe inspire comes with a removable band and the optional clip may be bought.
If it was me, I would first try putting the Charge in a pants pocket or tuck the strap under the waist band.
