01-23-2016 17:16 - last edited on 09-06-2020 17:10 by MatthewFitbit
01-24-2016 07:59
01-24-2016 07:59
@Luciej5 Welcome to the Fitbit Community! That usually happens when the tracker is not paired to your account. Make sure to follow all of these set up steps to fix. If after doing this it is still not showing the display when you turn your wrist, perform a restart.
Also, for call notifications after setting up the tracker, follow these set up steps as well.
Hope this helps. Let me know how it goes!
01-24-2016 07:59
01-24-2016 07:59
02-17-2019 20:49
02-17-2019 20:49
Did reboot of device but no help. Still not getting clock when moving wrist to check time.
11-27-2019 06:10
11-27-2019 06:10
After doing all of the above o still can not get the display to work not even to display the four digit codd to sync. What else can I do?
01-05-2020 20:23
01-05-2020 20:23
I found an answer in another post - the 'quick view' got turned off. For a charge 3 at least, press and hold the button on the side of the device briefly. you should see a display with 'screen wake' with a light bulb and 'notifications' with what looks like a smart phone with a text message box. if they are dim, they are off. touch them to turn them back on. Press the button again briefly to switch back to the normal mode, and it should be all set. this worked for 2 charge 3's that I know of.
04-06-2020 09:23
04-06-2020 09:23
Good advice except for one detail. You have to hold the button longer, until you see the smile icon. This is ten seconds or more.
