01-23-2019
		18:44
		20:07
		01-23-2019
		18:44
		20:07
My Fitbit Charge HR has been failing recently ie I'll look down at it at random times on random days and the display is blank and no green lights. Usually a restart procedure will get it going again. This has happened on multiple occasions. Yesterday I woke up to the same issue and went to plug into its cable and the usual USB charger and restart as previously. The result was no display, no green lights. My software was up to date before this occurred. I have read numerous posts for similar issues and followed the advice ie trying different cables (I have 2) and many USB chargers and computer ports. I have tried the restart procedure many times and I have also tried a factory reset. The result is always the same ie no display or green lights. Are there any other options for me?
Regards
Richard
Moderator Edit: Updated Subject for Clarity
01-23-2019 20:24
                              01-23-2019 20:24
Welcome to the forums!
Sounds like you have done all of the fixes you can try
Please contact support
Contact
http://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs
Im sure they will take good care of you
Wendy | CA | Moto G6 Android
01-23-2019 22:56
01-23-2019 22:56
Thanks Wendy. I have emailed support and will post the outcome, once I hear back.
Regards.
Richard.
 Best Answer01-24-2019 02:38
01-24-2019 02:38
Has stopped also... I'm a little concerned
 Best Answer01-24-2019 03:51
01-24-2019 03:51
I'll let you know what support 's advice is once I get it.
 Best Answer01-27-2019 23:23
01-27-2019 23:23
Support were helpful and despite my not being able to provide a receipt for warranty they did provide me with discount on the purchase of a new tracker.
 Best Answer01-31-2019 14:01
 Community Moderator Alumni are previous members of the Moderation Team, which ensures conversations are friendly, factual, and on-topic. Moderators are here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
                              01-31-2019 14:01
@richard.meagher Welcome to the Fitbit family! Thanks for taking the time to share the experience you have had with Charge HR not turning on. Thanks for trying all of those steps and for contacting customer support.
I'm really glad to read that customer support was able to help you out and provide you with a solution. Hopefully, this will be helpful for other users too.
@Bunnydoowop It's great to see you in the Fitbit forums! Thanks for reporting that you are also experiencing the same.
I'd recommend performing a restart on your tracker. This has helped other users in the past.
@WendyB Tanks for sharing your help on this thread!
Keep me posted!
