01-09-2019
12:52
20:07
01-09-2019
12:52
20:07
Screen has been stuck on a loading bar for approximately 24 hours now. This was after an update was done and the loading bar seems to be stuck at 50%. Tried a hard reset that was recommended by another user but did not change anything and screen is still stuck.
Moderator edit: Updated title for clarity
01-10-2019 09:15
01-10-2019 09:15
Hi there @sandyd54, welcome to the Fitbit Community Forums! 🙂
I'm very sorry to hear that you're having problems getting your Charge HR to work after updating it. Thanks a lot for trying the reset. Now, by this, does it mean that you just restarted the tracker or did you do a factory reset? Just to know the difference, a common restart works the following way:
For this, plug the charging cable to any USB port or UL-certified USB wall charger and plug the other end to your Charge HR. Press and hold the button for 10-12 seconds until you see the Fitbit icon and the version number and release the button.
If you've not tried doing a factory reset, you can also try that if the regular restart doesn't work. For this, follow the instructions on this article.
Hope this helps. Let me know if you need more help!
Best Answer01-11-2019 06:41
01-11-2019 06:41
I tried doing both a restart and a factory restart but my fitbit charge hr won't do it. It's stuck in the middle of an update and has a picture on it as if it's half loaded. What other options do I have?
Best Answer01-12-2019 10:24
01-12-2019 10:24
I am having the same issue after latest update. I did both reset methods. It works momentairly, then gets stuck in the loading screen.
Best Answer01-12-2019 16:06
01-12-2019 16:06
Mine is stuck half way as well.
It seems every time there is a new version, there are problems afterwards.
