01-23-2022
01:51
15:46
01-23-2022
01:51
15:46
Hi I'm using Fitbit coach (premium) und would like to see the same details for the coached activities as I would see for manually started activities (km, pace, gps track on map, etc.). However, when using audio coach I cannot start the track manually. It was possible previously with the coach app separately. Information currently available for audio coach activities is not sufficient. Am I using this the wrong way or is it not possible? If this was not possible it would be a poorly designed feature especially for this high subscription price.
thanks Sabine
02-16-2022 11:07
02-16-2022 11:07
Hi... just solved this.., one has to start the activity from the tracker PLUS the mobile. GPS mode is set to integrated, think this helps too. As a result one sees the result from the tracker with distance, pace, map view etc. and the result from the mobile / Fitbit coach. Greetings Sabine
Best Answer02-16-2022 11:07
02-16-2022 11:07
