01-23-2022
03:17
15:46
01-23-2022
03:17
15:46
Hello,
Around New Years, my Fitbit decided that it wasn't going to vibrate anymore. I made sure to check that Do Not Disturb and Sleep were off, and still nothing. Even when you try to change vibration strength it doesn't vibrate. Does anyone know of a fix?
The FitBit does not vibrate when plugged in. Is there anything that I can do to get the motor to start working again, or do I need a replacement?
Best AnswerI believe this is the part you need to replace (scroll and select Vibrator at $39.99):-
If the device still under warranty then contact support immediately. If out of warranty, I suspect Fitbit doesn't support such repair. You can check out with Fitbit support.
Depending on the tracker, it vibrates when you plug it in and reset the tracker.
https://help.fitbit.com/articles/en_US/Help_article/1186.htm
CharlesKn | Mid-Atlantic, USA
60+, strength and cardio
Charge 5, Android, Windows
Best AnswerThanks for the heads up. I've contacted support and they will email me with more instructions.
