01-22-2019
06:42
20:07
01-22-2019
06:42
20:07
I've been having issues with my Fitbit Charge HR for a few weeks.
It started when my the display flipped upside down and it stopped counting my steps. I decided to let the battery drain down completely, then recharge it and see if that fixes it. When it charged back up, the display is oriented correctly, but now the time is wrong (it's currently 8 hours behind the real time).
It appears to be syncing up, but the steps I never match the wrist band (it always shows less steps), however I don't have any sleep statistics or HR data since even before I noticed the original display issue.
I've confirmed that it's set to the right time zone, and went through the process of turning it off manually, per the process on another forum post, but it's still not working correctly.
Any thoughts?
01-22-2019 08:46
01-22-2019 08:46
It takes times from sync device each time it syncs.
If you are sure it is syncing, and it off by exact number of hours, try changing time zone to something else that is wrong, sync, then change back to correct zone and sync again.
01-22-2019 09:17
01-22-2019 09:17
So, after playing with some settings, within the App, actually saying it hasn't Synced since Dec 8, 2018 (despite having logged steps that seemed reasonable in the time since then).
So, I guess there's a bigger problem at hand.
01-22-2019 09:37
01-22-2019 09:37
See Can I see real-time data in the Fitbit app?
Some data can show on the app from the bluetooth link between phone and tracker without actually syncing through the main Fitbit database. That often causes confusion of people thinking they have synced when actually have not.
