01-10-2019
04:56
20:07
01-10-2019
04:56
20:07
I let my Fitbit charge fully overnight. I put my Fitbit on this morning and it was fine. It last synced about an hour ago and it was still fully charged. Now it's not working, no display, no green lights, nothing.... I have had it for about two years is it dead???
Moderator edit: Updated subject for clarity.
01-11-2019 08:36 - edited 01-11-2019 08:43
Thank you for reaching out to the Community @tsanders31, welcome!
I appreciate the details on your post. You can try the following steps:
Your tracker should now work normally. If your tracker still doesn't work after a restart, let me know.
As you mentioned that your Charge HR is about two years old, you can also clean the charging contacts on the back of it. These contacts can become obstructed by microscopic dirt or debris that prevents them from making a good connection to the charger. Use a toothpick or toothbrush to clean the charging contacts; do not scrape them with anything metal because this may damage the plating and result in corrosion.
We recommend plugging your charging cable into a USB port on your computer or other low-energy device. If necessary, you can use a UL-certified USB wall charger. Don't use a USB hub or battery pack to charge, and only use the charging cable that came with your tracker.
Hope this helps! See you around.
