01-13-2019
03:13
20:07
01-13-2019
03:13
20:07
My charge hr when i try to set up goes all the way through to giving me the code and then just sits there saying connecting......
I have tried resetting the charge hr, uninstalling and reinstalling the app, turned bluetooth on and off. Nothing works....
What else can be the problem?
01-14-2019 00:58
01-14-2019 00:58
This can happen if your phone is not supported by fitbit. Have you checked yours at www.fitbit.com/devices ?
Best Answer01-14-2019 00:58
01-14-2019 00:58
Best Answer01-14-2019 02:21
01-14-2019 02:21
Hi, yes i have a samsung galaxy s7.
Best Answer03-12-2019 15:00
03-12-2019 15:00
I have a 1 yr old phone: Motorola MOTOZ2. Wondering when my FitBit Charge 2 will be able to communicate with my phone. Very frustrated. This feature was my favorite with my first FitBit.
Best Answer03-27-2019 11:21
03-27-2019 11:21
I'm having the exact same problem. My phone is compatible and was working a few weeks ago. Now I dont know. I've uninstalled the app, force stopped the app, cleared the cache, switched bluetooth off and on, tried connecting over wifi or cell data. And I can still not connect.
Best Answer03-27-2019 11:24
03-27-2019 11:24
@Sweetsa things to try when you get connection problems are:
