10-07-2017
17:23
20:15
10-07-2017
17:23
20:15
Hi My Fitbit Charge HR has once again stuck in Firmware update mode. I have taken all the steps to reset it, sync and unsync, forget device, let the battery drain etc. However it does not appear to get out of software update screen, like a half filled bar. Anyone know how to fix this?
@willow01 Welcome to the Fitbit forums! Thanks for taking the time to share the situation you are experiencing with your Charge HR showing half bar on screen after the update.
In this case, that means that the update was not completed. Please try the following steps in order to sort this out. You will find two different workarounds there. Try them in the order given for best results.
Hope this helps. Keep me posted! ![]()
