06-10-2017
08:25
09:49
06-10-2017
08:25
09:49
I'm having trouble entering food log on my iPhone. I can log food entries on my computer, but not on my iPhone 6s. Can anyone help? Thank you! Also, how do I enter the barcode I've photographed?
06-13-2017
07:43
03:05
06-13-2017
07:43
03:05
Hey hey hey @Summerliz17, it is great to see new members around!
The Fitbit apps support barcode scanning. Just go to the screen where you log food and tap the barcode icon, then make sure the barcode on your food item is in front of your camera. You'll either see "Got it" if the food is recognized as belonging to our food database, or you'll be prompted to add the food to the food database. If the food isn't recognized, you'll need to manually add it to your food log.
Let me know if you need further assistance!
07:43
03:05
06-13-2017
07:43
03:05
Best AnswerI have the same problem did you find a solution
06:46
03:05
08-16-2017
06:46
03:05
Hi @Carolfaith and @Ilohe, let me give you a warm welcome to the Community guys! If you have questions about how to enter your food log, let me know specifically what are they, so I can further investigate them and give you an answer. 😉
Keep me posted!
Best AnswerHi there,
Can't find the barcode scan icon.
I live in France, wondering whether settings may vary according to country?
Thanks!
11:27
07:26
02-18-2019
11:27
07:26
Hey @Frogologue, I hope you are doin' fine! To scan a food item, complete these steps:
Let me know how it goes!
Best AnswerThanks for trying to help!
Actually, I got the bar code thing all worked out, but I live in France and, apart from a couple of international brands, most local bar codes are just not recognized.
Do you have many French users? Might be worthwhile looking around for a DB with the info.
FWIW, just downloaded Yuka and will give it a try.
Bests!
PS: new here and pretty allergic to forums
so not familiar with etiquette. Do I generally need to e.g. @HeydyF when I reply?
11:37
03:05
02-19-2019
11:37
03:05
Hi @Frogologue! No, you don't need to etiquette all the time, but it helps to get a faster response. 🙂 Now in regards of international food, at the moment, logging food via bar-code scanning is only supported for the US food database, so most local food in France or any other country will not be recognized.
Hope this helps and let me know if you have further questions!
