11-25-2016
01:47
10:26
11-25-2016
01:47
10:26
11-25-2016 16:18
11-25-2016 16:18
This happened to my old HR. I got my Charge 2 and left the HR on my dresser for weeks. It was dead. Completely. I picked it up one day and it showed 3000 steps. My kids swear our house is haunted- well you can imagine what happened next. I don't know why it happened other than the ghost wore it. I don't think it is anything to worry about from a faulty perspective. Once you are back on your feet, it will do the good job it did before you had to take a break. Wishing you a speedy recovery!
Elena | Pennsylvania
11-26-2016 08:47
11-26-2016 08:47
Hi @BeverleyM63 welcome to the Community. To be honest, that's very weird.. Is the tracker located in a place that involves any movement? Sometimes the tracker keeps recording steps although it's no longer charged. I also wish you a good recovery!
Thank you for your help @emili ![]()
Parliamo di calcio Qual è la tua squadra di calcio preferita?
.11-26-2016 09:04
11-26-2016 09:04
Best Answer11-26-2016 22:55
11-26-2016 22:55
@BeverleyM63 I see you are happy with your Fitbit One. Are you still using it, and is it connected to the account as the Charge 2? If so when the tracker a sync, Fitbit will try and sync up both trackers. This has affect of transferring the step count from the Fitbit One to your Charge 2.
11-27-2016 01:29
11-27-2016 01:29
Best Answer11-27-2016 19:25
11-27-2016 19:25
Best Answer11-27-2016 19:57
11-27-2016 19:57
10-04-2019 10:01
10-04-2019 10:01
I found your post because I was googling "ghosts/spirits messing with my fitbit" I SWEAR this thing has vibrated on me ~ usually when I'm half awake or asleep but there's no alarm or notification, etc set to go off, nothing at all. Mine is a newer one, just from Mother's Day of 2019...
Maybe it's just a "glitch", maybe I was having a dream, maybe it's a "something else"...
