11-15-2016
09:24
10:26
11-15-2016
09:24
10:26
Is there a way to stop the Chatter function on the Fitbit Charge 2. I don't have a greeting set and I don't have quick view enabled, but when my device hasn't moved for a while, it lights up with a message like 'ready, set go', etc... I don't mind if I've not had it on for a while and pick it up, but it is annoying me and my hubby when it does it in the middle of the night
I would like to use the device for tracking my sleep, but I won't whilst it does this.
11-15-2016 09:30
11-15-2016 09:30
11-16-2016 05:30
11-16-2016 05:30
@Lynne888 Welcome to our Community! There is no option to disable the Chatter on your tracker although it shouldn't show that often. I actually have read about people not even getting the messages on their tracker or hardly ever seeing them. Still you could add your idea to the Feature suggestion board to request an option to disable and enable Chatter messages.
Let me know how it goes!
03-18-2017 06:07
03-18-2017 06:07
How can you get the greetings and chatter to work
03-21-2017 09:30
03-21-2017 09:30
@Lebron I hope you're doing well! You can set the Chatter messages on your tracker's settings area under "Tap Display" options. It will show messages when you move your tracker encouraging to keep it up, mine show messages when it detects I am waking up or when I leave the tracker for a period of time while taking a bath and pick it up.
Best Answer01-28-2020 15:51
01-28-2020 15:51
Thanks @AlvaroFitbit , I found your reply while looking for the chatter option on Charge 3.
I can find the option on Alta HR, but can't find it anywhere in Charge 3, and the tracker doesn't show these messages.
Any idea how to enable on Charge 3?
Best Answer01-28-2020 21:19
01-28-2020 21:19
@MHanafy as previously mentioned, and as you have pointed out, there isn't an option for chatter on the Charge 3. So yes, currently this can not be enabled.
Have you added your vote to the current 36 votes
Best Answer01-28-2020 21:33
01-28-2020 21:33
Thanks @RI Just did now; hopefully this gets prioritized.
It's frustrating to see the cheaper/older models have this feature, while Charge3 doens't!
Best Answer01-28-2020 21:37
01-28-2020 21:37
@MHanafy you tagged the wrong user.
