07-21-2020
14:08
13:23
07-21-2020
14:08
13:23
Hi, suddenly heart rate stopped working, very annoying, I did the reboot on my Charge3 bit nothing happened, anyone else with this problems??
09-03-2020 04:15
09-03-2020 04:15
I have got the same problem. I fully charged my Charge3 and after that my heart rate stopped showing 2 days ago. Green light is no longer on and the clock is not showing the time completely
09-03-2020 07:02
09-03-2020 07:02
My charge started vibrating and the screen was changing rapidly draining the battery life to less than 24 hours right before the firmware update. Most of the function returned but the HR monitor has not worked since then (so no sleep or activity tracking because of this also). I have rebooted it more times than I can count. I hope someone answers this thread so we can get some help.
Best Answer09-03-2020 07:54
09-03-2020 07:54
09-04-2020 05:35
09-04-2020 05:35
Yes I have the same problem see posts. I have contacted fitbit support but they haven't resolved the problem. It was escalated yesterday but I still haven't heard off them.
09-04-2020 06:14
09-04-2020 06:14
No, my green light isn't working and my screen seems to do what it wants at times. I was hoping you had heard from them, but it seems that everyone is getting a slow response. Bummer.
09-04-2020 07:29
09-04-2020 07:29
Best Answer09-04-2020 07:39
09-04-2020 07:39
09-04-2020 07:40
09-04-2020 07:40
I have had my charge3 more than 12 months now so I don't think its under warranty now but thanks anyway.
09-04-2020 07:41
09-04-2020 07:41
Still waiting will update once I get a response.
Best Answer09-17-2020 12:37
09-17-2020 12:37
I still haven't heard anything. Have you had any luck?
Best Answer09-17-2020 12:42
09-17-2020 12:42
Still dead quiet... like my charge 3
09-17-2020 12:42
Same problem
