Hello!
I inherited a Fitbit device from my daughter. She doesn't have the box or the User Manual.
How could I identify the Fitbit device model, download the User's Manual and reset it for my use?
I append some pictures of the Fitbit device.
Thank you for your support.
Hi @FernandoKneese there's an easy way to know what you have. Download the app to your smartphone and set it up. When you go through the process, it will ask you if you want to pair with the Fitbit "whatever style" so you'll know then which one you have. You can find user manuals on the "Help" page upper right of this page. You might not want to print the entire manual out, but that link does have helpful articles and videos. It does look like a Charge, just not sure which version.
@FernandoKneese I'm very confident that your tracker isn't a Fitbit at all and I think it is a tracker made by ANCwear. Check out all the available photos.
Laurie | Maryland
