01-14-2020 21:35 - last edited on 09-24-2020 19:06 by
Hi,
I was playing with the settings on my Charge 3 and accidentally turned off the auto brightness. Now the screen is too dark to see anything and turn it back on. I have tried to see if there are settings on the app and restarted it with no luck
Thanks
01-15-2020
05:03
08:09
01-15-2020
05:03
08:09
Welcome to the Community, @JessJT.
To adjust the brightness of your Charge 3, you just need to swipe to settings directly from the device and tap the brightness option to the one you prefer.
Let me know if you need anything else.
Best AnswerI almost had to call fitbit myself. It was so dim I couldn't read where the settings part was. I can't find this info anywhere on the site. The settings button is 3 swipes in on the bottom. Brightness is then on the top. I went into a dark room and by trial and error finally found it. This should really be somewhere more obvious on the app on the phone.
