11-29-2019
04:44
10:32
11-29-2019
04:44
10:32
Can the brightness of the face of the Charge 3 be adjusted? Find it hard to see as compared to Charge 2.
11-29-2019 08:34
11-29-2019 08:34
There are 3 settings for brightness: auto, dim, normal.
From main clock face, scroll right (swipe left) to 'Settings'. Tap Settings, then scroll up or down to Brightness.
If you have already done this and still find it not bright enough, there's nothing else that can be done.
Best Answer11-29-2019 08:34
11-29-2019 08:34
Best Answer11-30-2019 04:04
11-30-2019 04:04
02-12-2020 15:24
02-12-2020 15:24
My Charge 3 is so dim that I cannot see the main clock face in order to swipe to settings. How can you see what is on the face when it is so dim. I called tech support the first time this happened to me and they helped me get it right.
Best Answer02-08-2021 06:16
02-08-2021 06:16
Thanks that worked.
