02-09-2020
14:29
14:21
02-09-2020
14:29
14:21
Hi all, I just got my Charge 3 because my Charge 2 died. The cleaning instructions said wipe with mild soap? What's mild soap? Also when I have a bath or shower, I'm taking it off. I clean it daily with alcohol after my shower/bath. Is this OK? Thx
See Wear & Care .
FOR ELASTOMER BANDS:
07:35
07:15
02-10-2020
07:35
07:15
It's great to see you here, @Carolxi and @JohnnyRow, thanks for the input.
I was able to see here that our friend @JohnnyRow provided some instructions about your cleaning inquiry. Was this the answer you were looking for? If it was, I recommend marking the answer given as the best answer. By doing this, other users with the same inquiry will be able to find a faster response.
Now, if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out.
Best AnswerHi, yes, this is in the manual. I've also been told to clean the contacts with alcohol. Is cetaphil a skin cleanser. I use a kleenex, dampened (not soaked) with alcohol. On the back of the tracker and the part of the band that touches the skin. I also clean that part of my wrist with alcohol. An on line helper said this was fine . I just don't know why we have to use this cetaphil.
