11-07-2020
03:43
12:57
11-07-2020
03:43
12:57
How do i delete alarms from my charge 3.
11-07-2020 15:27
11-07-2020 15:27
Hi
I can help with that problem that you have having!!!
follow these steps
1: turn on your device
2: go to alarms
3:select a alarm
4: scroll down and tap on the bin
5: select the tick and enjoy then!!!
11-07-2020 15:27
11-07-2020 15:27
Hi
follow these steps
2: go to alarms
3:select a alarm
11-08-2020
11:08
08:30
11-08-2020
11:08
08:30
@Ubique11 It's great to have you here!
Thank you for your inquiry. @Akas has provided you a great guide on how to do this. Remember that you can also check our help site for these type of questions. Still happy to see that you got help from the Community.
Happy stepping and stay safe.
Best Answer11-08-2020 15:59
11-08-2020 15:59
I figured it out. The X and the check mark was my confusion.
Best Answer04-14-2021 14:32
04-14-2021 14:32
There is no bin when you tap on the Alarm. There are alarms and after scrolling, + to add more. i want to delete all old alarms.
