10-06-2020
00:55
16:17
10-06-2020
00:55
16:17
How do I remove the health and well-being notifications of my Charge 4? I am getting about 30 reminders a day and it is getting really annoying!
10-08-2020 04:02
10-08-2020 04:02
Hi,
I have found out what to do.
On your fitbit app, top left corner tap on your name/your account. Then tap on Your Device. You can then see your apps and it is in the list underneath to turn off health and well-being reminders. I have turned mine off so it definitely works.
Let me know how you get on 😊!
10-07-2020 07:12
10-07-2020 07:12
Welcome to the Community, @BEChick.
If you want to disable some of your notifications, I recommend trying the following:
Let me know the outcome.
10-07-2020 20:05
10-07-2020 20:05
I also somehow signed up for these style of notifications "Don't let the day get away - take a minute away from screens"
I have looked in the Notifications as mentioned above but cannot identify what these are and they are getting very annoying and causing my battery to drain quickly.
Thanks if you can help, Janet
10-07-2020 22:29
10-07-2020 22:29
I phoned for some advice about these notifications. I used the live chat.. twice. No help whatsoever. Once you allow these health and well-being notifications then you are basically stuck with them. There is no way to disable, so they tell me, unless you select Do Not Disturb. Not very helpful at all 🤔
10-08-2020 01:13
10-08-2020 01:13
I thought when I clicked the button they said you could unsubscribe at any time, they are a real nuisance I hope they can figure a way to stop them. Thanks for the feedback
10-08-2020 04:02
10-08-2020 04:02
Hi,
10-09-2020 08:10
10-09-2020 08:10
10-15-2020 01:28
10-15-2020 01:28
Oh thank YOU !! I have found that and switched it off so now hopefully they will STOP what a nuisance they were and draining the battery !! Thank you again 🙂
10-16-2020 07:33
10-16-2020 07:33
I am glad to hear that your Charge 4 works properly, @JanetFet and that your settings are correct. If there is anything else we can help you with, do not hesitate to post it.
Keep the stepping up!
12-27-2020
13:44
08:32
JuanJoFitbit
12-27-2020
13:44
08:32
JuanJoFitbit
Hi everybody,
Since a week I have the same notifications coming out of nowhere, and I can't seem to turn them off.
I watched the instructions given by @BEChick but I don't see the option "health and well-being reminders". I do have the dutch app, but nothing like that... I don't know how to turn it off. Hope someone can help!
Kind regards, Sofie
Oh, I forgot, I have a fitbit versa (1). I don't think it mattes that much, but just in case!
Moderator edit: merged reply
12-30-2020 10:37
12-30-2020 10:37
Hey @Sofywo, it's great to see you around.
Thanks for letting us know about the issue you are experiencing with the "health and well-being reminders" option not showing. We are aware of the problem and are working to resolve it as quickly as possible, sorry for any inconvenience it's caused and appreciate your patience and look forward to getting you back on track.
Please let me know if there's anything I may do to assist you in the meantime.
01-01-2021 01:53
01-01-2021 01:53
01-03-2021 09:51
01-03-2021 09:51
Thanks for getting back, @Sofywo.
I understand how are you feeling. While we don't have a timeline for resolution, we will continue to investigate these discrepancies. Your patience and understanding will be much appreciated.
Let me know if you need anything else.
01-10-2021 07:42
01-10-2021 07:42
Did you ever get a response to this? I don't have that option either.
01-10-2021 07:43
01-10-2021 07:43
Will there be anything to indicate that we have that option when it's available? Those messages are horribly annoying. I don't have the option to turn them off either.
01-10-2021 08:08
01-10-2021 08:08
Hi
On the app, click on the top left corner where your profile picture is.
Go down to where is says Charge 4.
Click on that.
Scroll down to general.
Click on health and wellness reminders and unselect them.
Hope this helps 😊
01-10-2021 08:14
01-10-2021 08:14
It doesn't help, because we don't have this option, so kind of hard to unselect... I will return mine. Fitbit let down number 2 (first versa died when swimming in a pool.). Shame of fitbit.
01-10-2021 10:29
01-10-2021 10:29
Unfortunately, I don't have "Health and Wellness" to click on. 🥺
01-10-2021 10:36
01-10-2021 10:36
Hello guys, I appreciate your participation in the Forums.
As mentioned previously, our team is aware of the problem and are working to resolve it as quickly as possible, sorry for any inconvenience it's caused and appreciate your patience and look forward to getting you back on track.
04-03-2021 07:26
04-03-2021 07:26
Hi, I have this same issue. I was actually hoping it would be resolved when I got the latest update, so I held off on messaging until then. But I still do not have the Health and Wellness reminders option in my list. I noticed this is a fairly old thread here. Just wondering, are they are still working on this issue?
I'm kind of annoyed when I'm in the middle of a run and my watch is telling me I should sit down and relax, or, another good one is when I'm just starting a 10 hour shift at work. It is really a minor annoyance, sort of bordering on being funny. But I just want to shut it off, and I can't.
I have a Charge 4, and I live in Canada (if that is relevant)
