05-13-2019
12:04
11:08
05-13-2019
12:04
11:08
My charge 3 device lock is always on "Only use for payments" I want to select for always.
Please help me. ![]()
05-14-2019 04:14 - edited 06-23-2024 08:39
Welcome to the Fitbit Community @ApplePlayz! You must enter your PIN code at least once a day. Your Fitbit device prompts you to enter your PIN code based on your device lock setting:
Note that your card issuer may require you to re-enter your PIN code to authorize a payment.
To change the device lock setting:
Hope this helps, let me know if you need further assistance. ![]()
Best Answer12-20-2019 18:59
12-20-2019 18:59
It doesn't give me an option to change it to always on.
09-15-2020 10:39 - edited 09-23-2020 17:00
How do you change the setting from Enabled for fitbit pay to enabled, my phone dosen't show an option, I am using charge 4 and an iPhone 7. 😭😭😭😭😭
12-03-2020 14:59
12-03-2020 14:59
Same issue!
I have enabled Fitbit pay and I cannot change the Device Lock options.
Best Answer03-26-2021 21:35
03-26-2021 21:35
Kindly address the issue being discussed here. We don't get an option to keep it turn on every time we wear it or after every 24 hours. We can't enable or disable it ourselves. Is this a broken feature?
same problem with charge 4 : https://community.fitbit.com/t5/Charge-4/I-can-t-enable-or-disable-Fitbit-device-lock-I-want-it-to-a...
Please help us out.
Best Answer03-17-2022 17:09
03-17-2022 17:09
How do I do it without Fitbit pay
