10-26-2018
12:55
15:03
10-26-2018
12:55
15:03
Howw do i reset day and on charge 3
10-29-2018 11:43
10-29-2018 11:43
Hey there @Burrismj, it's nice to see you around! While reading your post I was wondering what you meant by resetting day and on Charge 3?
Was your data not automatically reset after midnight? Your Fitbit device resets your data to zero each night at midnight. For most devices, your minute-to-minute data is stored in your tracker for up to 7 days without syncing. A daily summary of your activity is stored for up to 30 days.
While I wait for your reply, here are the steps on how to restart your tracker:
Looking forward to your reply.
12-18-2018 07:10
12-18-2018 07:10
My Charge 3 just show horizontal bar after failed to finished intallation.
It is not responding now.
How to restart?
Thanks
Best Answer12-18-2018 08:01
12-18-2018 08:01
Thanks for jumping in here @LesterRyan! In order to restart your Charge 3, please follow the steps I've posted here.
If your tracker is still showing the horizontal bar, can you please attach me a picture showing it?
Looking forward to your response! ![]()
Best Answer12-18-2018 14:52
12-18-2018 14:52
Thank you, it is working now...
Best Answer01-01-2019 11:33
01-01-2019 11:33
My fitbit charge 3 will not reset. Followed the instructions. Its plugged in and battrs shows as 72%. Holding button for up to 20 sec at a time and no change, Tried numerous times. Can a reset be done via the PC?
Best Answer01-02-2019 05:40
01-02-2019 05:40
What button are you all referring to? My Charge 3 does not appear to have one?
Best Answer01-28-2019 12:19
01-28-2019 12:19
It's on the side of the fitbit to the left of the clock face .. looks like a depression
Best Answer02-23-2019 21:46
02-23-2019 21:46
My charge 3 was syncing with both my iphone 5S and iPad and then three days ago stopped syncing. I have tried doing the recharge by holding the button for 8 seconds until the smiley face comes up but it is still not syncing.
Best Answer02-24-2019 06:12
02-24-2019 06:12
I seem to be having this problem as well. Connected to the charging cable and holding the side button for a long time but it doesn't reset. How did you fix your problem
Best Answer02-24-2019 13:13 - last edited on 02-20-2020 15:56 by LiliyaFitbit
I haven't managed to reset mine either. Frustrating!!!
Best Answer02-24-2019 23:01
02-24-2019 23:01
Best Answer02-26-2019 14:24
02-26-2019 14:24
My charge 3 is also not syncing correctly I’ve had four Fitbit’s always been a bit flakey to sync but this one is now totally refusing to do it correctly keeps downloading only today not the day before and then loosing it.. won’t then sync to the challenge I’m in really really frustrating..l bought the charge after my ionic threw a wobbly in the pool and I had to have it replaced... Fitbit sort out your quality control . I love the app it’s whats keeping me with you but if I can’t get it to work I will start looking for new options.
Best Answer02-26-2019 14:25
02-26-2019 14:25
Ps I did get it to smilie face but it didn’t make a difference
Best Answer02-26-2019 14:37
02-26-2019 14:37
My Fitbit used to sync to my iPad and iPhone 7 but for some reason wont sync with my iPhone 7 anymore the Fitbit won’t pair with my phone
Best Answer12-28-2019 14:37
12-28-2019 14:37
Tried to reset fitbit several times but still getting a completely blank screen
Best Answer01-19-2020 09:32
01-19-2020 09:32
I don't get a vibration when I put my charger on. When I push the button in for 8 seconds, nothing happens except it goes back to the time screen. No vibration, no smiley face. Totally and thoroughly frustrated with this. I do have to use an adapter for the charging cable because my computer is a Mac with USB C. Could that be a problem?
Best Answer06-27-2020 13:44
06-27-2020 13:44
first of all every time I have to do this I find multiple processes and lots of times it doesnt work. It is the one thing I really hate about the tracker. I need a charge before I finsh my walk and I cant get it to charge
Best Answer06-27-2020 13:50
06-27-2020 13:50
I am trying to get my fitbit to show me the time on the screen I have it charged but it a black screen nothing comes up can someone tell me how to fix that
Best Answer06-27-2020 14:42 - last edited on 07-16-2020 20:14 by LiliyaFitbit
the whole reset thing is hit or miss for me. I wish they would just have a
reset slot because I push on the side button and nothing happens. after
about an hour it did start to charge but not because of the instructions,
Good luck
*Democracy Dies in Darkness- WAPO*
