09-19-2016
		11:35
		20:15
		09-19-2016
		11:35
		20:15
Please how do i reset date & time.
09-19-2016 11:50
                              09-19-2016 11:50
Time comes from your mobile or dongled computer when you sync @Santaray
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
09-19-2016 11:49
                              09-19-2016 11:49
When you sync your Charge HR it should set the date and time.
It is also a good idea to make sure your timezone is set correctly. You can check this in Account settings --> Advanced settings.
Any more questions, just ask. There is always someone here to help. Welcome to the Community!
09-19-2016 11:50
                              09-19-2016 11:50
WmChapman | TX
04-26-2017 11:28
04-26-2017 11:28
how do I change time and date
 Best Answer04-26-2017 11:41
04-26-2017 11:41
my computer does not put the proper time or date in.
Sandy
 Best Answer07-30-2017 17:36
07-30-2017 17:36
How do I reset the time & Date on my Fitbit Charge 2 after not using it for while?
 Best Answer02-07-2018 13:23 - edited 02-07-2018 13:26
The time shows up but it's wrong. The date doesn't show up. How long must it be left to sync? Maybe I didn't let it finish....? I wish I knew more about this. What does dongled mean? I think it means that you must be connected to your computer via the charging cord....? Must I do something else besides just charge it? I read the instructions, but maybe I didn't follow them correctly.
 Best Answer01-18-2019 15:01
01-18-2019 15:01
How can I reset the time and date on my Fitbit after not wearing it for a few weeks?
 Best Answer01-21-2019 13:44
01-21-2019 13:44
I haven't worn my alta for 3 weeks. How do I reset date and time
 Best Answer01-21-2019 13:51
                              01-21-2019 13:51
@Deb2800, as mentioned above, when you sync your Fitbit, it will reset the date and time.
If youe Fitbit is having trouble syncing, the first step is to give it a restart. If that doesn't get it syncing, please work carefully throught these sync troubleshooting steps
