10-05-2016
04:17
20:15
10-05-2016
04:17
20:15
Hi
My Fitbit Charge HR is currently under warranty with a local supplier and has a few problems, however I require a serial number to process the warranty, I do not have the original packaging, where can I find it?
I have checked old posts and they say to check for the 12 Hex code here: https://www.fitbit.com/settings/device/tracker/<Serial_Number> , is this correct?
Thanks
10-05-2016 05:13
10-05-2016 05:13
No it is not, I compared it to my serial number recently.. Many stores scan both the barcode and serial number at the time of purchase, they should have a record but maybe won't be able to pull it up.. It also might be on the receipt which you also don't have.
This means your only a to contact.fitbit.com.
Best Answer10-05-2016 05:36
10-05-2016 05:36
Thanks for the response
Will get in touch with Fitbit
Best Answer05-21-2019 23:12
05-21-2019 23:12
Can you seen the serial number in fitbit app?
Best Answer05-23-2019 16:07
05-23-2019 16:07
