01-14-2020 06:48 - last edited on 09-24-2020 19:06 by
I want to see the number of steps not the feet on the Fitbit watch. How do I do that?
Thanks
01-15-2020
03:54
08:11
01-15-2020
03:54
08:11
It's great to see you around, @Sammy16cam.
You will see your information depending on the clock face you select. If you haven't checked our clock faces, I recommend doing it by following the instructions provided in the help article: How do I change the clock face on my Fitbit device?.
Let me know how it goes. 🙂
01-16-2020 05:54
01-16-2020 05:54
Thanks that’s what I needed it worked
01-16-2020 06:49
01-16-2020 06:49
Or you could just guess your step count as that would be as accurate as using a Fibit, Good luck trying to make sense of the next two weeks 👍
Best Answer01-16-2020 07:24
01-16-2020 07:24
Mine seems to work well. I have noticed that a lot of people are having trouble with sync issues my Fitbit works well. My step count is accurate as well. I guess I am one of the lucky ones. I got my Fitbit on Christmas.
Best Answer01-16-2020 07:54
01-16-2020 07:54
I wish you all the luck in the world, U are going to need it.
07:45
08:10
01-19-2020
07:45
08:10
Thanks for the update, @Sammy16cam and participation.
I am glad to hear that your Charge 3 is working properly. If there is anything else we can help you with, do not hesitate to post it.
Happy stepping! 🙂
